Unable to get any information on node message on the same node
Is there anyway to fix this problem? I get the problem only on this node and have 50 other devices that work fine. I have tried the repair functions but no luck. Once before when this happened I reset the power to the zwave module and it worked again but the home is not near me so this is a pain because I have to go there to do it. There are many devices close to this one so the signal strength should be fine
I have Vera 2 with the latest beta firmware and GUI is 15.The device is an Aeon in wall switch controller which I am using to control a solenoid value for watering the lawn.
Hi Farnell,
We need a bit more of info here.
What Vera do you have and what UI are you running?
Also, what device does not respond?
Flo
I had a similar issue with a GE/Jasco receptacle mounted in the ceiling of my garage, one of the furthest nodes from Vera, although I have the same device 10’ further that did not have this issue.
The only difference was the type of box they were installed in, and when I changed the metal box of the non responding node to a plastic one, the problem has not resurfaced.
