I have an Ezlo Plus and while able to create scenes in the past, I can not, any more, if they invove devices. I can create a scene and have it change the mode of the controller, but if I try to have it turn something on or off, it will not accept the “Action” entry. I can add “Actions”, but when I click “Done”, the action is not there.
I have tried the “Reconstruct Z-Wave Network”, and it does not change anything.
I only have six devices “Paired” on my network, and I only have seven scenes set up. So I should not be hitting any limits, unless it counts the ones I’ve created and deleted as sill being in effect. They are not.
Oops, you’re right. I’m using iOS and version 3.53 (13).
I did create 20 scenes a couple of weeks ago, and periodically, I have tried to add one, and the “+” sign is grayed out. But now I can’t add any scenes with only the seven scenes on the device. It’s almost as if there is a counter set as scenes are added, then rather than use the actual number on the program, it is using the counter value. But then again, if you are correct that the 20-scene limit has been lifted, something else must be going on.
This is a known issue with app version 3.53 (13) currently being worked on by the iOS team. The internal ticket Log in - MiOS is where it’s being worked on. It is not accessible like those created from the forum, but it’s good to keep it here to keep track of the issue. It should be corrected for a future update.
Actually, it may be that some variation of the 20-scene limit has me stopped. I created 20 scenes, and after deleting several of them, I am still unable to create any new scenes. It will let me start the process, name the scene, select a trigger, but when I try to enter an action, it will not take it. The “Save Scene” box is grayed out. Also, as soon as I select “Done” after selecting an Action, it goes away.
So at this point, I only have 7 scenes, and can’t add any more. It’s getting to be really discouraging. Hopefully the fix is just around the corner.
