I am attempting to connect to my Vera Controller using the web interface via the relay.
This is the screen I am getting when I attempt to connect.
Any information on how to resolve this error.
Thank you.
Thank you.
Here are the network settings when I get this error. External IP that shows is correct but has been omitted.
Thank you,
Hi @Canz
This issue is likely related to the server relay your Vera controller is using (probably relay 52). Please PM me the serial number of your Vera controller and enable remote access on it from Settings>Customer Care so I can verify web access once I switch the server relay on it.
