[quote=“birchey, post:5, topic:189007”][quote=“integlikewhoa, post:4, topic:189007”][quote=“birchey, post:3, topic:189007”]I am still having issues with this. I managed to add one trigger once, that was it. Since then every time i try to add a trigger in any of my PLEGS it doesn’t stick
Has anyone come across this issue, as currently PLEG is unusable for me.
I have seen issues being mentioned on the forum, but they were more around the upgrade of vera, these issue seem to have started on the last update of PLEG
Anyone got any ideas on this?[/quote]
The lastest PLEG plugin update only works with the latest Vera update.
Vera released the last update and it broke PLEG vera alerts and a few others.
Richard released an update for PLEG and Vera alerts after that to fix it but it is not backwards compatible with an older version of UI7.
So if you had auto update on for your PLEG but haven’t updated VERA, then that’s your problem.
Your options (if your in that boat) are to update vera or restore your vera back before PLEG was updated and turn off auto update. People have found it auto updates instantly so you many need to disable your outside internet or modem so vera is unable to update while you disable auto update.[/quote]
Thanks for the response, i was aware of this and i suffered with the triggers until the new release of of PLEG came out.
The first trigger issue after the vera update was you couldn’t select any device, i can do that now. As stated i am on Vera edge on 1.7.1419 with Program Logic Core version 7.48 and Program Logic Event Generator version 7.47
So not sure what the resolution is to this issue[/quote]
I am having a similar issue. I can’t add any triggers to my current PLEG setup and my conditions/actions that used to work flawlessly randomly aren’t working. It’s quite annoying. For the record, I also am on Vera edge on 1.7.1419 with Program Logic Core version 7.48 and Program Logic Event Generator version 7.47
