So I bridged my Vera3 and Vera Lite together by adding a UPNP device like the instructions say, just as a test.
And it worked. ???
The problem is, I’ve searched the forum high and low for how to undo it. I can find no shortage of threads on issues with bridging and how to get it to work, but can’t find anything on how to undo the bridge. I want to repurpose my old Lite as a standalone ‘test’ unit.
Either way I’m sure it’ll all go pear shaped when I give the Lite a new reserved IP in DHCP so would like to break the bridge before I change the IP.
I would also like to know how to unbridge. In my efforts to get my VeraEdge and VerLite bridge (finally successful) I got them bridge in both directions and would like to break one of those bridges so that it only goes one way.
Well it looks like I stumbled across the answer by accident.
On the “Master” Vera you want to unbridge from (in my case the Vera 3), I was using PLEG to add an action and noticed Device #343 MIOS in my device drop down list.
I then used the http command to delete a hidden device:
http://MY_VERA_IP:3480/data_request?id=device&action=delete&device=343 (Replace the device number with your device number.)
This removed the MIOS UPNP device and all of the Vera Lite devices from the Vera 3.
