Has anyone installed this yet? How’d it go if you did?
I’m a bit leary after the last update fiasco.
BTW, still no updated to the CRAPPY Android App.
https://goo.gl/qz9rLe - Release notes
[code]I7 ▾ Vera Software Update ▾ Version 7.0.26 (1.7.1028/1.7.3797/1.7.3798/1.7.3799) ▾ May 2, 2018
Last Updated: May 2, 2018
Firmware
Vera3, VeraLite, & VeraLite G: 1.7.1028
VeraEdge: 1.7.3797
VeraPlus: 1.7.3798
VeraSecure: 1.7.3799
New Features
VeraEdge, VeraPlus, and VeraSecure (Series 500 controllers) compatible with the latest Z-Wave SDK (6.81, Z-Wave version 6.1).
Easier migration from Vera 3, VeraLite (Series 300 controllers), and the process is now a regular backup and restore.
Z-Wave routing of large networks improved, and redesigned backup and restore functionality.
Note: The backup and restore functionality may not work in some cases. Please contact Customer Care for assistance.
New Security Settings:
This option is mostly for developers which create or change MiOS plugins: Enable potentially unsafe Lua code, like wget and RunLua. Having this option enabled might cause unexpected behavior with some plugins or Lua code.
Enable UPnP. This will make your Vera discoverable and controllable by other UPnP devices.
Fixes and Improvements
Better handling of simultaneous recording uploads
Improved network connectivity detection for faster 3G backup connections
Fixed a synchronization issue that was preventing proper relay configuration to be applied to the controller
Updated notifications (cloud fix)
Affects all customers, regardless of beta status, or live status or older controllers
Now when a basic user is present in the list, other users remain listed (cloud fix)
Now door lock pins added manually from the door lock are visible in the interface
Now special characters are accepted when using the VeraEdge and switching Wi-Fi Access Points
Email notifications display the correct temperature format
Scenes editor improvements for Lua code section
Improved scene trigger editing flow allows changes without asking the user to re-enter time restrictions
API improvements for Zigbee devices (lu_jobstatus fixed)
Known Issues
Only on controllers that have an external USB Z-Wave dongle (USB plugged), communication with devices is lost after upgrade in some cases.
When using Google Chrome versions starting with v59, live streaming no longer works on local connections due to new Adobe Flash Player policy restricting the stream
Minor issue when adding some cameras in some cases using only a VeraPlus and SYNC (WPS) button
Unable to record video in Foscam FI9821W (Mjpeg)
Only in a bridge environment, NodOn Wall Switch disappears from the web UI
“Controller Down” alerts are sent when the relay servers are merely switching
Note: Controllers switch from one relay server to another as a backup only when the controller cannot communicate with the main server assigned to it. Reasons why a controller switches depend on external factors like the customer’s network, ISP or server issues, etc. If the connection drops, the controller jumps to another server
[VeraSecure] Even with the Wi-Fi option re-enabled, the UI displays the “Manually configure” option as being selected
Samsung Appliances are not yet available for usage in Scene actions.
Newly integrated devices
Scene controller
Aeotec WallMote Dual ZW129*
Sensor
Fibaro Door/Window Sensor 2 FGDW-002*
Switches and Dimmers
Philio Smart Energy Plug-In Switch PAN15*
Philio Z-Wave Smart Dimmer Socket PAD02*
Garage door opener
Linear Pro Access Smart Garage Door WFWS-8XX
*Note: For full compatibility of the newly integrated or hot-fixed devices, we recommend excluding and re-including them from the unit, after the upgrade is complete.
MOBILE APPS
WINDOWS
New Features
New setup flow: Easier Vera account setup and controller activation
My Controller: A new way to easily add a new controller or remove existing ones from your account
Settings→ Users: Now manage additional users for your Vera controller
New Software Update Card: Prompts you to upgrade the latest firmware
New Login screen
Now easily see your controllers that are online, offline or on Cellular Backup via My Controller
Faster load time and scrolling on Devices Page
Geofencing: Improved communication of Geofencing events when Internet connection is slow or switching from Wi-Fi to cellular
Camera images are now correctly shown when using “Manual Camera Wizard”
Philips Hue Bridge Presets can now be triggers in Scenes
Philips Hue bulb sliders are available in Preset Modes
The loader / empty list message is now visible on all screens
Preset Modes are now populated in all situations
The device height is now correctly set on Preset Modes when Devices are in List Mode
The warning icon appears on a device now only when it is in an error state
Thermostat state and temp can now be changed using Preset Modes
Many other fixes and improvements
Known Issues
At this time there are no reported blocking issues
iOS
New Features
New watch features (Note: after you connect to the controller via the iOS app, the watch app can be used):
New: From your watch, see devices added to your favorites list.
New: Switch devices on/off with your watch app only (without a phone). Note: watch must be internet connected
New: See views from your cameras from your watch. Note: cameras must be added to favorites list
Now control devices and Scenes with your voice, using the new microphone button in the app
Now door lock pins added manually from the door lock, are visible in the app
Fixed an issue where the account was blocked for 5 minutes after entering a wrong password twice
Now controller always appears online and offline accurately
Now editing is available behind the fourth button of Aeotec Wallmote Quad
Fixed an issue where the values of the dimmers weren?t saved in preset modes
Known Issues
There could be performance issues on older devices such as iPad 4 or iPhone 5. Clearing the in-memory apps and reloading the app is recommended in case of missing devices.
[/code]
