So, I finally moved to the 7.30 stable version on my Edge and it seems OK. On my second day and no major problems.
I have problems pairing Fibaro Smart Implants, but I’m not 100% sure this is related to this new FW. Next week I’ll be less busy and I’ll try other routes. New devices should be incorporated sooner, but that’s another story.
Got distracted earlier today and instead of updating the iOS I ended up pressing the trigger on the firmware update. No stopping it once it started.
As it happens all went well and it appears to be functioning normally on the Vera Edge. I know there’s been no major reports of issues with the FW update on a Vera Edge but now the wondering if is finally over for me.
Earlier today my automation stopped working so I logged into my Vera Plus to find that the entire configuration had been wiped showing the dashboard wizard, etc. When I access the main page, it jumps to the firmware page and shows 1.7.4819 (7.30) as the current version. It is interesting because I did not do anything to prompt this behavior - I haven’t added any devices or changed the configuration in over a week.
That said, I restored from an Nov-30 backup, including z-wave, and everything is back to normal but it is curious as to why this happened in the first place. Thank goodness for a reliable built-in backup and restore capability.
Just posting as an FYI in case it helps @sorin and @edward.
Can you tell if the unit rebooted? By that I mean a warm start or power cycle, not a LUUP reload. I saw this during the initial upgrade to 7.30. Once the unit got out of Xmas tree mode, it came up as a clean configuration and required loading a backup to get back to normal.
My VeraPlus seemed to be working last night, on .29. I noticed some writing errors, which on my Vera 3 meant it needed a reboot. Or at least, it was not an issue before.
This morning, I noticed my bedroom ceiling light did not turn off when my nightstand lamps ramped up. Bathroom automation was working, thermostat was set correctly, cameras were disarmed, so did not think too much about it.
I tried to log into the VeraPlus from my tablet, but I could not “find” its IP address in my browser. Tried to login using the Vera website and it reported by VeraPlus was offline. So I unplugged it, plugged it back in, and now it cannot get an an IP address from the Router - flashing Internet and Service lights.
Did a network reset, then a factory reset - still a flashing Internet and Service lights.
Tried lots of different combinations - flashing Internet and Service lights.
My next step is to log into its wi-fi to see if I can SH into the box to nose around a bit. I hope this is not firmware related. Very strange behavior.
In the meantime, I got my Vera 3 out of the garage, did a restore, and I am back in business until I can get the VeraPlus back up.
In all of the times I’ve gotten the “Xmas Lights” problem, which has been often since 4800, I have never once had to reset network settings or factory reset to recover the box. Power-cycling alone has done the job. But, you need to make sure your Internet access is up and running (and if not static, your DHCP server) when you do. In my experience:
Reboot/restart when Internet access is not available will, some high percentage of the time, result in Xmas Lights mode;
If the box is up and running fine but Internet access drops out for more than an hour, it pretty much always/guaranteed ends up in Xmas Lights mode (i.e. sustained Internet outages result in a soft-bricked Plus);
Randomly I will get Xmas Lights mode on any random reload, but I haven’t figure out the specific conditions for that.
But anyway, the point of my reply here is, for you and others, don’t run straight for the large hammers and long knives when you get Xmas Lights mode. First, make sure you have working Internet access (ping 8.8.8.8 from somewhere, open sites on your browser, or whatever you normally do when a family members suggests there’s no Internet), and then, only when you know it’s good, just power cycle the box. As I said, I haven’t yet had to push the Big Red Button this way.
Graphing DHCP latency, it appears? I’m not sure what story that tells.
Unfortunately, I (too) often see total loss of routing with my ISP, while link is up and I can hit their gateway. Usually I can see several nodes deep into their network, and then some internal routing issue blackholes the traffic (it’s Comcast, and they make extensive use of proxies, so I suspect they often bonk). The result is no accessible Interwebs, despite happy lights in all the places most might first look.
Yeah, I’ve seen the same on both Comcast and now Spectrum. So while the above graph could be happy and the link effectively down, that didn’t happen in this case. My Vera woke the house up just fine this morning and I was happily hacking away using a continuous Internet connection when it decided to bork itself. Still a mystery to me but I don’t think the Internet connection is the root cause. I posted this mainly to add to the triage heap for @edward
My house system is running 7.30 (4800) LuaUPnP on the 7.29 OS, and it’s pretty solid. I’m inclined to agree with @rafale77 's suspicion that there’s brokenness in the kernel, but I also don’t think it’s the only problem introduced by the OS changes.
I’m running the 4819 7.30 Protect release for the V+ that @sorin posted but that may have been pulled??? All betas before that with pretty good luck. A little bumpy recently but nothing I wouldn’t expect by running betas along the way to the final release.
All good advices! Please don’t go crazy when you get the xmas light mode problem. Generally after a few attempts, it ends up booting without having to do anything else. In the worst case, you have to run a restore from backup and this is about it.
I can only say that if this is related to internet connections, it is way too sensitive. I have zero problem with my internet connection and even have dual WAN failover. I had ~80% failure to reboot with the released 7.0.30.
The remedies for now are one of the following:
If you don’t use the mios cloud (remote access, mobile app) disable the network monitor program.
If you really need the above functionalities of the vera then the only solution I found so far has been to start from a 7.0.29 setup, never having upgraded to 7.0.30. Get it extrooted and run the non standard upgrade script I offered in th extroot thread. I have now verified for over 20 manual reboots that I never get this problem Vs. the 80% failure rate with a standard upgrade.
Indeed, through my testing, I found that the Christmas Light mode can be prevented using the same network monitor program running the previous kernel. The kernel is on a different partition than the rootfs and does not get downgraded if you downgrade from 7.0.30 to 7.0.29.
@phillid2, since your problem is on 7.0.29, it is likely very different from what others are reporting. There is another set of issues if you vera is connected to your network through wifi instead of ethernet.
Had the same reboot to default last night on my Vera Plus running 1.7.4800 (7.30). Did nothing more than just reboot the Vera that has been happily (more or less) running the 4800 firmware since I upgraded weeks ago.
I rebooted my vera because when I attempted to access the dashboard directly, it just showed a “Toggle …” button and two broken picture links. However, accessing from the relay servers worked fine.
Rebooting presented the welcome wizard and a blank dashboard. Luckily the restore including zwave brought everything back. However, it is quite concerning this happened.
Internet connectivity was fine during this time as reporting by cloud controller monitoring, and multiple ping targets way beyond ISP.
I have another Vera Plus at a remote location running 4800 and now displaying a similar screen when directly accessing it via VPN. I am really worried about rebooting that one remotely.
I have a vera secure and it keeps going into “Christmas tree mode”. from my reading it looks like we are waiting for a firmware update? Can support remotely fix this? Is the another solution?
