What is the proper way to setup a scene that will turn on the lights in the garage when I open either of the garage doors? I tried a simple trigger on whenever the garage door “turns on”, turn on the lights, and this doesn’t work. Any help would be appreciated.
Create one scene with two triggers. One for each garage door. Then try to manually trigger it. This should tell you whether the problem is the trigger or the execution of the scene. If you can manually trigger it, it means your trigger is not setup right. I did the same thing and have not had any problem…
