UI7 Scene Control Question
2+ years on Vera3 with UI5 without any problems. I could use scene controllers to arm and disarm the ELK1 panel, no problem.
Have now moved to UI7.
When I try to set up a scene to arm the ELK1 panel, I can set the ‘trigger’ just fine, however, when choosing an “action” to take, the "Partition 1: " selection is not there. If I choose Alarm Panel, all I get is the opportunity to ‘clear’ it. Not able to set an arm or disarm state.
What am I missing?
Thanks!
Bill Walters
OK, found a way to do it using home “MODE” that I can specifically change using SCENT assignment in the remote control widget.
The functionality is there, just ‘buried’.
What a system…
