Managed to get my Vera Lite back into life after a firmware update to UI7. Ended up doing hard reset.
How can I get all temperature sensors and the weather widget to display in degrees centigrade please?
Go to Unit Settings and you can change it there.
There is not section or tab called ‘unit setting’ under version 1.7.374 that I can see.
Users & Account Info > Unit Settings
Would be nice if I could access this ![]()
Every time I click on the tab labelled ‘User and Account Info’ it displays the sub-menu options and then takes me back to https://home.getvera.com/dashboard/myunits regardless of what I do next. There is a bug with the UI7 s/w from what I can see.
There sure is. I can only access this page after authenticating with home.getvera.com. It’s hard to see why I need to authenticate myself to set something as basic as the unit system. I suspect it was an oversight.
Probably, like everything Vera, this works better on some browsers than others. Try a couple.
Edit: Are you feeling adventurous, and know your way around a Unix shell? You can hand-edit the userdata to set the temperature scale. It’s in the TemperatureFormat attribute of the root element. Here’s how: http://forum.micasaverde.com/index.php/topic,5154.msg81276.html#msg81276
