Hi, is there any possibility to use more than 20 characters on the device name?
In UI5 I did not have any limits (although I never noticed).
In UI7 it is only 20 charachters and that too little in most cases.
Use this link. It is a manual work around since Vera has blocked names with more than 20 characters (no idea why).
http://ip_address:3480/data_request?id=device&action=rename&device=ID&name=DEVICE_NAME&room=ROOM
ID = Device’s ID, available in advanced settings.
NAME = Name of device. It needs to use html characters, for example, a space is %20.
ROOM = the id of the room the device belongs in. View in device settings.
If your device’s name is more than 20 characters and you change the room of the device… the name is truncated… funny
