UI7 and AV Gear
I am trying to add in AV Gear and setup automated scenes like turning a TV on and off. I cannot find a place to add in my AV gear in UI7. Is this a known issue? Any knowledge of if / when this will be fixed?
Though I don’t use UI7, I don’t believe that UI7 has native support for “AV gear”. AV gear is usually TCP/IP or IR connected equipment that Vera (UI5 at least) can control by use of a plugin. Did you install an appropriate plugin?
I have the plugin installed (Global Cache), but technically when you are in UI5, you have the ability to add devices that are controlled via IR, etc… with the plugins. I cannot find the place to add an AV device.
I agree AV control is missing from the current UI firmware aka 7.02
Looking at the release notes, it appears it is not included and there is statement in the forum about future release , that info is not available. For current inf see http://support.getvera.com/customer/portal/articles/1756945-ui7-▾-version-7-0-2-1-7-439-▾-nov-11-2014?b_id=712
I would raise a ticket with support to establish what is the intended release that would include it and they should be able to provide more info… http://getvera.com/support/
I’ll put in a ticket.
Technically, VeraEdge is on a higher release (1.7.850) than what those release notes are for. Still missing in this release :slight_smile:
Yes, I understand there are different firmware versions for the Edge, but I have never seen any corresponding release for the Edge… Hopefully you have added this to the ticket.
