Am on 459 beta firmware.
I have installed dataMine so many times tonight its not working!!
" dataMine graphing and logging[26] : Startup Lua Failed"
I’m only using one usb drive - no logging - where am i going wrong
what settings do i need
I have ssh into the box - and the drive shows as /dev/sda1/
I have even tried manually mounting " mount /dev/sda1 /datamine/ " into the shell but it doesnt work !!!
Variables
SetDataDirectory
SetMountUUID
SetMountPoint
SetManualMount
SetTimeoutPeriod
SetHistoryEnable
SetUseBackup
SetEventsEnable
ChannelCnt
ChannelRec
mountLocation
mountType
LastUpdate
New service:
ChrisJ
April 15, 2013, 3:57pm
2
Are you able to get the log file? If you have WinSCP, then first restart Luup to make sure we view the log when there’s an error, then in the terminal box in WinSCP type “cat /var/log/cmh/LuaUPnP.log | grep -i DataMine”. Hopefully this would tell me where it’s failing.
You will ultimately need to use the UUID setting - not the mount since the mount can change each time Vera starts (and actually, it can change even when Vera is just sitting there! >:().
Chris
06 04/15/13 21:51:36.941 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: SetMountUUID was: 747E4EEA7E4EA4A8 now: 747E4EEA7E4EA4A8 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2e835680>
09 04/15/13 21:51:52.400 JobHandler_LuaUPnP::Run device 32 dataMine graphing and logging room 0 type urn:schemas-cd-jackson-com:device:DataMine:1 id parent 0/0x7f7310 upnp: 0 <0x2ace2000>
50 04/15/13 21:52:01.508 luup_log:32: dataMine: Initialising dataMine System (0.975) <0x2b615680>
06 04/15/13 21:52:01.509 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: ChannelCnt was: 0 now: 0 #hooks: 0 upnp: 0 v:0x8848d8/NONE duplicate:1 <0x2b615680>
06 04/15/13 21:52:01.519 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: ChannelRec was: 0 now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2b615680>
50 04/15/13 21:52:01.520 luup_log:32: dataMine: Mounting to UUID ‘747E4EEA7E4EA4A8’ <0x2b615680>
50 04/15/13 21:52:02.549 luup_log:32: dataMine: UUID = /dev/sdb1: UUID=“747E4EEA7E4EA4A8” <0x2b615680>
50 04/15/13 21:52:02.565 luup_log:32: dataMine: Found UUID ‘747E4EEA7E4EA4A8’ at ‘/dev/sdb1’ <0x2b615680>
50 04/15/13 21:52:02.588 luup_log:32: dataMine: Error reading tmpfile during mountcheck <0x2b615680>
06 04/15/13 21:52:02.588 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: mountLocation was: now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2b615680>
06 04/15/13 21:52:02.588 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: mountType was: now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2b615680>
50 04/15/13 21:52:02.605 luup_log:32: dataMine: Mounting dataMine storage (/dev/sdb1) to (/dataMine/) <0x2b615680>
50 04/15/13 21:52:02.694 luup_log:32: dataMine: Error reading tmpfile during mountcheck <0x2b615680>
06 04/15/13 21:52:02.694 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: mountLocation was: now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2b615680>
06 04/15/13 21:52:02.695 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: mountType was: now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2b615680>
50 04/15/13 21:52:02.711 luup_log:32: dataMine: Mount point error: ::/dev/sdb1 <0x2b615680>
50 04/15/13 21:52:02.722 luup_log:32: dataMine: ERROR: Startup state is ‘uninitialised’! <0x2b615680>
06 04/15/13 21:52:02.722 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: ChannelCnt was: 0 now: 0 #hooks: 0 upnp: 0 v:0x8848d8/NONE duplicate:1 <0x2b615680>
06 04/15/13 21:52:02.722 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: ChannelRec was: 0 now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2b615680>
50 04/15/13 21:52:02.723 luup_log:32: dataMine: Reinitialising configuration structure <0x2b615680>
50 04/15/13 21:52:02.723 luup_log:32: dataMine: Startup complete <0x2b615680>
01 04/15/13 21:52:17.217 LuaInterface::CallFunction_Timer-5 function deferredStartup failed [string “-- dataMine Plugin for Vera…”]:725: bad argument #1 to ‘sort’ (table expected, got nil) <0x2c615680>
06 04/15/13 21:53:16.041 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: SetMountUUID was: 747E4EEA7E4EA4A8 now: 747E4EEA7E4EA4A8 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2ce15680>
09 04/15/13 21:53:28.705 JobHandler_LuaUPnP::Run device 32 dataMine graphing and logging room 0 type urn:schemas-cd-jackson-com:device:DataMine:1 id parent 0/0xe272c8 upnp: 0 <0x2b819000>
50 04/15/13 21:53:37.718 luup_log:32: dataMine: Initialising dataMine System (0.975) <0x2c14d680>
06 04/15/13 21:53:37.719 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: ChannelCnt was: 0 now: 0 #hooks: 0 upnp: 0 v:0xeb54f8/NONE duplicate:1 <0x2c14d680>
06 04/15/13 21:53:37.720 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: ChannelRec was: 0 now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2c14d680>
50 04/15/13 21:53:37.720 luup_log:32: dataMine: Mounting to UUID ‘747E4EEA7E4EA4A8’ <0x2c14d680>
50 04/15/13 21:53:38.793 luup_log:32: dataMine: UUID = /dev/sdb1: UUID=“747E4EEA7E4EA4A8” <0x2c14d680>
50 04/15/13 21:53:38.818 luup_log:32: dataMine: Found UUID ‘747E4EEA7E4EA4A8’ at ‘/dev/sdb1’ <0x2c14d680>
50 04/15/13 21:53:38.853 luup_log:32: dataMine: Error reading tmpfile during mountcheck <0x2c14d680>
06 04/15/13 21:53:38.854 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: mountLocation was: now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2c14d680>
06 04/15/13 21:53:38.854 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: mountType was: now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2c14d680>
50 04/15/13 21:53:38.891 luup_log:32: dataMine: Mounting dataMine storage (/dev/sdb1) to (/dataMine/) <0x2c14d680>
50 04/15/13 21:53:39.015 luup_log:32: dataMine: Error reading tmpfile during mountcheck <0x2c14d680>
06 04/15/13 21:53:39.015 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: mountLocation was: now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2c14d680>
06 04/15/13 21:53:39.016 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: mountType was: now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2c14d680>
50 04/15/13 21:53:39.051 luup_log:32: dataMine: Mount point error: ::/dev/sdb1 <0x2c14d680>
50 04/15/13 21:53:39.062 luup_log:32: dataMine: ERROR: Startup state is ‘uninitialised’! <0x2c14d680>
06 04/15/13 21:53:39.062 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: ChannelCnt was: 0 now: 0 #hooks: 0 upnp: 0 v:0xeb54f8/NONE duplicate:1 <0x2c14d680>
06 04/15/13 21:53:39.063 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: ChannelRec was: 0 now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2c14d680>
50 04/15/13 21:53:39.063 luup_log:32: dataMine: Reinitialising configuration structure <0x2c14d680>
50 04/15/13 21:53:39.064 luup_log:32: dataMine: Startup complete <0x2c14d680>
01 04/15/13 21:53:54.163 LuaInterface::CallFunction_Timer-5 function deferredStartup failed [string “-- dataMine Plugin for Vera…”]:725: bad argument #1 to ‘sort’ (table expected, got nil) <0x2d14d680>
manually entering /dev/sdb1 into dialog
9 04/15/13 21:56:48.818 JobHandler_LuaUPnP::Run device 32 dataMine graphing and logging room 0 type urn:schemas-cd-jackson-com:device:DataMine:1 id parent 0/0xe8e508 upnp: 0 <0x2b146000>
50 04/15/13 21:56:58.208 luup_log:32: dataMine: Initialising dataMine System (0.975) <0x2ba79680>
06 04/15/13 21:56:58.208 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: ChannelCnt was: 0 now: 0 #hooks: 0 upnp: 0 v:0xf1beb0/NONE duplicate:1 <0x2ba79680>
06 04/15/13 21:56:58.209 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: ChannelRec was: 0 now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2ba79680>
06 04/15/13 21:56:58.209 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: mountLocation was: /dev/sdb1 now: ** Manual #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2ba79680>
06 04/15/13 21:56:58.210 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: mountType was: now: ** Manual #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2ba79680>
50 04/15/13 21:56:58.225 luup_log:32: dataMine: Manual mounting to (/dataMine/) <0x2ba79680>
50 04/15/13 21:56:58.237 luup_log:32: dataMine: ERROR: Unable to open config file for read :: /dataMine/dataMineConfig.json <0x2ba79680>
01 04/15/13 21:56:58.261 LuaInterface::CallFunction_Startup-1 device 32 function initialise failed [string “-- dataMine Plugin for Vera…”]:725: bad argument #1 to ‘sort’ (table expected, got nil) <0x2ba79680>
01 04/15/13 21:56:58.262 LuImplementation::StartLua running startup code for 32 I_DataMine1.xml failed <0x2ba79680>
what non vera ways are there to log if i cant get this to work ??
can I log directly to another server??
ChrisJ
April 15, 2013, 9:15pm
6
See the updated software and instructions at the following link. I believe this will fix your problem I believe since your log shows the same error as in the other post.
[url=http://forum.micasaverde.com/index.php/topic,7750.msg109496.html#msg109496]http://forum.micasaverde.com/index.php/topic,7750.msg109496.html#msg109496[/url] .
Cheers
Chris
will have a look - thanks for the quick reply!!
no luck. after uploading that file.
I just keep on getting the USB configuration page.
I’m not manually setting anything.
more dump
04/15/13 22:23:25.064 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: SetMountUUID was: EMPTY now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2b885680>
06 04/15/13 22:23:25.065 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: SetMountPoint was: EMPTY now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2b885680>
06 04/15/13 22:23:25.065 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: SetManualMount was: EMPTY now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2b885680>
06 04/15/13 22:23:25.066 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: SetTimeoutPeriod was: EMPTY now: 12 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2b885680>
06 04/15/13 22:23:25.066 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: SetHistoryEnable was: EMPTY now: 1 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2b885680>
06 04/15/13 22:23:25.067 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: SetUseBackup was: EMPTY now: 1 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2b885680>
06 04/15/13 22:23:25.067 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: SetEventsEnable was: EMPTY now: 1 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2b885680>
06 04/15/13 22:23:25.068 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: ChannelCnt was: EMPTY now: 0 #hooks: 0 upnp: 0 v:0xdd2150/NONE duplicate:0 <0x2b885680>
06 04/15/13 22:23:25.069 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: ChannelRec was: EMPTY now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2b885680>
50 04/15/13 22:23:25.069 luup_log:32: dataMine: Installing update of dataMine web application <0x2b885680>
50 04/15/13 22:23:31.662 luup_log:32: dataMine: ERROR: Startup state is ‘uninitialised’! LEAK this:90112 start:385024 to 0x1069000 <0x2b885680>
06 04/15/13 22:23:31.662 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: ChannelCnt was: 0 now: 0 #hooks: 0 upnp: 0 v:0xdd2150/NONE duplicate:1 <0x2b885680>
06 04/15/13 22:23:31.663 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: ChannelRec was: 0 now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2b885680>
50 04/15/13 22:23:31.663 luup_log:32: dataMine: Reinitialising configuration structure <0x2b885680>
50 04/15/13 22:23:31.664 luup_log:32: dataMine: Startup complete <0x2b885680>
50 04/15/13 22:23:46.082 luup_log:32: dataMine: Delete backups complete - deleted 0 of 0 files <0x2c885680>
09 04/15/13 22:25:47.204 JobHandler_LuaUPnP::Run device 32 dataMine graphing and logging room 0 type urn:schemas-cd-jackson-com:device:DataMine:1 id parent 0/0xb1cd58 upnp: 0 <0x2b595000>
50 04/15/13 22:25:54.946 luup_log:32: dataMine: Initialising dataMine System (0.976.1) <0x2bec9680>
06 04/15/13 22:25:54.947 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: ChannelCnt was: 0 now: 0 #hooks: 0 upnp: 0 v:0xbab758/NONE duplicate:1 <0x2bec9680>
06 04/15/13 22:25:54.947 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: ChannelRec was: 0 now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2bec9680>
50 04/15/13 22:25:54.958 luup_log:32: dataMine: ERROR: Startup state is ‘uninitialised’! <0x2bec9680>
06 04/15/13 22:25:54.958 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: ChannelCnt was: 0 now: 0 #hooks: 0 upnp: 0 v:0xbab758/NONE duplicate:1 <0x2bec9680>
06 04/15/13 22:25:54.958 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: ChannelRec was: 0 now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2bec9680>
50 04/15/13 22:25:54.959 luup_log:32: dataMine: Reinitialising configuration structure <0x2bec9680>
50 04/15/13 22:25:54.960 luup_log:32: dataMine: Startup complete <0x2bec9680>
50 04/15/13 22:26:09.076 luup_log:32: dataMine: Delete backups complete - No files found LEAK this:8192 start:405504 to 0xe47000 <0x2cec9680>
06 04/15/13 22:26:09.094 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: diskTotal was: EMPTY now: 11264 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2cec9680>
06 04/15/13 22:26:09.095 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: diskUsed was: EMPTY now: 6576 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2cec9680>
06 04/15/13 22:26:09.095 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: diskFree was: EMPTY now: 4688 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2cec9680>
06 04/15/13 22:26:09.096 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: diskUsedPcnt was: EMPTY now: 58 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2cec9680>
06 04/15/13 22:26:20.785 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: SetMountUUID was: now: 747E4EEA7E4EA4A8 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2d6c9680>
09 04/15/13 22:26:35.855 JobHandler_LuaUPnP::Run device 32 dataMine graphing and logging room 0 type urn:schemas-cd-jackson-com:device:DataMine:1 id parent 0/0x829828 upnp: 0 <0x2ad54000>
50 04/15/13 22:26:43.961 luup_log:32: dataMine: Initialising dataMine System (0.976.1) <0x2b687680>
06 04/15/13 22:26:43.961 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: ChannelCnt was: 0 now: 0 #hooks: 0 upnp: 0 v:0x8b81e8/NONE duplicate:1 <0x2b687680>
06 04/15/13 22:26:43.962 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: ChannelRec was: 0 now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2b687680>
50 04/15/13 22:26:43.962 luup_log:32: dataMine: Mounting to UUID ‘747E4EEA7E4EA4A8’ <0x2b687680>
50 04/15/13 22:26:44.961 luup_log:32: dataMine: UUID = /dev/sdb1: UUID=“747E4EEA7E4EA4A8” <0x2b687680>
50 04/15/13 22:26:44.977 luup_log:32: dataMine: Found UUID ‘747E4EEA7E4EA4A8’ at ‘/dev/sdb1’ <0x2b687680>
50 04/15/13 22:26:45.000 luup_log:32: dataMine: Error reading tmpfile during mountcheck <0x2b687680>
06 04/15/13 22:26:45.000 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: mountLocation was: EMPTY now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2b687680>
06 04/15/13 22:26:45.001 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: mountType was: EMPTY now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2b687680>
50 04/15/13 22:26:45.017 luup_log:32: dataMine: Mounting dataMine storage (/dev/sdb1) to (/dataMine/) <0x2b687680>
50 04/15/13 22:26:45.109 luup_log:32: dataMine: Error reading tmpfile during mountcheck <0x2b687680>
06 04/15/13 22:26:45.110 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: mountLocation was: now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2b687680>
06 04/15/13 22:26:45.110 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: mountType was: now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2b687680>
50 04/15/13 22:26:45.126 luup_log:32: dataMine: Mount point error: ::/dev/sdb1 <0x2b687680>
50 04/15/13 22:26:45.137 luup_log:32: dataMine: ERROR: Startup state is ‘uninitialised’! <0x2b687680>
06 04/15/13 22:26:45.137 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: ChannelCnt was: 0 now: 0 #hooks: 0 upnp: 0 v:0x8b81e8/NONE duplicate:1 <0x2b687680>
06 04/15/13 22:26:45.138 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: ChannelRec was: 0 now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2b687680>
50 04/15/13 22:26:45.138 luup_log:32: dataMine: Reinitialising configuration structure <0x2b687680>
50 04/15/13 22:26:45.139 luup_log:32: dataMine: Startup complete <0x2b687680>
06 04/15/13 22:26:58.783 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: SetMountUUID was: 747E4EEA7E4EA4A8 now: 747E4EEA7E4EA4A8 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2ce87680>
50 04/15/13 22:27:00.162 luup_log:32: dataMine: Delete backups complete - No files found <0x2c687680>
06 04/15/13 22:27:00.179 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: diskTotal was: 11264 now: 11264 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2c687680>
06 04/15/13 22:27:00.180 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: diskUsed was: 6576 now: 6580 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2c687680>
06 04/15/13 22:27:00.180 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: diskFree was: 4688 now: 4684 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2c687680>
06 04/15/13 22:27:00.181 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: diskUsedPcnt was: 58 now: 58 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2c687680>
09 04/15/13 22:27:13.556 JobHandler_LuaUPnP::Run device 32 dataMine graphing and logging room 0 type urn:schemas-cd-jackson-com:device:DataMine:1 id parent 0/0xd98d38 upnp: 0 <0x2ab70000>
50 04/15/13 22:27:22.706 luup_log:32: dataMine: Initialising dataMine System (0.976.1) <0x2b4a3680>
06 04/15/13 22:27:22.707 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: ChannelCnt was: 0 now: 0 #hooks: 0 upnp: 0 v:0xe26220/NONE duplicate:1 <0x2b4a3680>
06 04/15/13 22:27:22.707 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: ChannelRec was: 0 now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2b4a3680>
50 04/15/13 22:27:22.707 luup_log:32: dataMine: Mounting to UUID ‘747E4EEA7E4EA4A8’ <0x2b4a3680>
50 04/15/13 22:27:23.751 luup_log:32: dataMine: UUID = /dev/sdb1: UUID=“747E4EEA7E4EA4A8” LEAK this:69632 start:233472 to 0x109f000 <0x2b4a3680>
50 04/15/13 22:27:23.777 luup_log:32: dataMine: Found UUID ‘747E4EEA7E4EA4A8’ at ‘/dev/sdb1’ <0x2b4a3680>
50 04/15/13 22:27:23.804 luup_log:32: dataMine: Error reading tmpfile during mountcheck <0x2b4a3680>
06 04/15/13 22:27:23.805 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: mountLocation was: now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2b4a3680>
06 04/15/13 22:27:23.805 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: mountType was: now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2b4a3680>
50 04/15/13 22:27:23.840 luup_log:32: dataMine: Mounting dataMine storage (/dev/sdb1) to (/dataMine/) <0x2b4a3680>
50 04/15/13 22:27:24.032 luup_log:32: dataMine: Error reading tmpfile during mountcheck <0x2b4a3680>
06 04/15/13 22:27:24.032 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: mountLocation was: now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2b4a3680>
06 04/15/13 22:27:24.032 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: mountType was: now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2b4a3680>
50 04/15/13 22:27:24.073 luup_log:32: dataMine: Mount point error: ::/dev/sdb1 <0x2b4a3680>
50 04/15/13 22:27:24.094 luup_log:32: dataMine: ERROR: Startup state is ‘uninitialised’! <0x2b4a3680>
06 04/15/13 22:27:24.094 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: ChannelCnt was: 0 now: 0 #hooks: 0 upnp: 0 v:0xe26220/NONE duplicate:1 <0x2b4a3680>
06 04/15/13 22:27:24.094 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: ChannelRec was: 0 now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2b4a3680>
50 04/15/13 22:27:24.095 luup_log:32: dataMine: Reinitialising configuration structure <0x2b4a3680>
50 04/15/13 22:27:24.095 luup_log:32: dataMine: Startup complete <0x2b4a3680>
50 04/15/13 22:27:39.162 luup_log:32: dataMine: Delete backups complete - No files found LEAK this:8192 start:380928 to 0x10c3000 <0x2c4a3680>
06 04/15/13 22:27:39.180 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: diskTotal was: 11264 now: 11264 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2c4a3680>
06 04/15/13 22:27:39.180 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: diskUsed was: 6580 now: 6580 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2c4a3680>
06 04/15/13 22:27:39.181 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: diskFree was: 4684 now: 4684 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2c4a3680>
06 04/15/13 22:27:39.181 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: diskUsedPcnt was: 58 now: 58 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2c4a3680>
06 04/15/13 22:27:45.753 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: SetMountUUID was: 747E4EEA7E4EA4A8 now: 747E4EEA7E4EA4A8 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 LEAK this:180224 start:565248 to 0x10f0000 <0x2dca3680>
09 04/15/13 22:27:58.727 JobHandler_LuaUPnP::Run device 32 dataMine graphing and logging room 0 type urn:schemas-cd-jackson-com:device:DataMine:1 id parent 0/0x7efd30 upnp: 0 <0x2b20d000>
50 04/15/13 22:28:07.822 luup_log:32: dataMine: Initialising dataMine System (0.976.1) <0x2bb41680>
06 04/15/13 22:28:07.823 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: ChannelCnt was: 0 now: 0 #hooks: 0 upnp: 0 v:0x87d9a0/NONE duplicate:1 <0x2bb41680>
06 04/15/13 22:28:07.823 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: ChannelRec was: 0 now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2bb41680>
50 04/15/13 22:28:07.823 luup_log:32: dataMine: Mounting to UUID ‘747E4EEA7E4EA4A8’ <0x2bb41680>
50 04/15/13 22:28:08.814 luup_log:32: dataMine: UUID = /dev/sdb1: UUID=“747E4EEA7E4EA4A8” <0x2bb41680>
50 04/15/13 22:28:08.830 luup_log:32: dataMine: Found UUID ‘747E4EEA7E4EA4A8’ at ‘/dev/sdb1’ <0x2bb41680>
50 04/15/13 22:28:08.854 luup_log:32: dataMine: Error reading tmpfile during mountcheck <0x2bb41680>
06 04/15/13 22:28:08.854 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: mountLocation was: now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2bb41680>
06 04/15/13 22:28:08.854 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: mountType was: now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2bb41680>
50 04/15/13 22:28:08.871 luup_log:32: dataMine: Mounting dataMine storage (/dev/sdb1) to (/dataMine/) <0x2bb41680>
50 04/15/13 22:28:08.979 luup_log:32: dataMine: Error reading tmpfile during mountcheck <0x2bb41680>
06 04/15/13 22:28:08.979 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: mountLocation was: now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2bb41680>
06 04/15/13 22:28:08.980 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: mountType was: now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2bb41680>
50 04/15/13 22:28:08.996 luup_log:32: dataMine: Mount point error: ::/dev/sdb1 <0x2bb41680>
50 04/15/13 22:28:09.007 luup_log:32: dataMine: ERROR: Startup state is ‘uninitialised’! <0x2bb41680>
06 04/15/13 22:28:09.007 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: ChannelCnt was: 0 now: 0 #hooks: 0 upnp: 0 v:0x87d9a0/NONE duplicate:1 <0x2bb41680>
06 04/15/13 22:28:09.007 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: ChannelRec was: 0 now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2bb41680>
50 04/15/13 22:28:09.008 luup_log:32: dataMine: Reinitialising configuration structure <0x2bb41680>
50 04/15/13 22:28:09.009 luup_log:32: dataMine: Startup complete <0x2bb41680>
50 04/15/13 22:28:23.163 luup_log:32: dataMine: Delete backups complete - No files found <0x2cb41680>
06 04/15/13 22:28:23.181 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: diskTotal was: 11264 now: 11264 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2cb41680>
06 04/15/13 22:28:23.181 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: diskUsed was: 6580 now: 6580 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2cb41680>
06 04/15/13 22:28:23.182 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: diskFree was: 4684 now: 4684 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2cb41680>
06 04/15/13 22:28:23.182 Device_Variable::m_szValue_set device: 32 service: urn:cd-jackson-com:serviceId:DataMine1 variable: diskUsedPcnt was: 58 now: 58 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2cb41680>
is it because I have beta firmware 1.459? If I downgrade will I loose my settings?
I really want to use this plugin!
ChrisJ
April 15, 2013, 10:15pm
9
That’s cleared the error that you were having, so there is progress, but it’s clearly still not working correctly as it can’t mount the USB now. I doubt this will be related to the beta software, so don’t downgrade.
Let me have a closer look at the log and see if I can come up with some ideas… I’m sure we’ll get it working.
Actually, now that we’ve cleared the initialisation error, the debug page should work, and this will give me a bit more information. If you go to the dataMine device in UI5 and click on the debug link it would be great if you could send the dump to me…
Thanks.
Cheers
Chris
ChrisJ
April 15, 2013, 10:25pm
10
I’m not sure, but this may be the problem. Either try unmounting (from the terminal in WinSCP, umount /datamine/ might work. The other alternative is to restart your Vera and see if that helps.
The problem appears to be that dataMine isn’t finding the mounted drive - it’s searching for /dataMine without the / on the end, which generally seems to work. This appears not to be working on your setup, so it may be something to do with your manual mount. It’s a bit of an educated guess, but worth a try.
Chris
Simply solved by naming the label!!! didnt realise this was different from the UUID
apologies.
by the way - how can datamine be accessed remotely through mios server?
^^ ignore question about remote view
will this be something in the future?
ChrisJ
April 19, 2013, 6:36pm
13
[quote=“sunshine, post:12, topic:175044”]^^ ignore question about remote view
will this be something in the future?[/quote]
Unfortunately, it’s not (securely) possible to do this through the MCV forward servers. Something needs to host the webpage since the forward servers don’t return this. If you put the GUI somewhere else, then it would work, but it would be a security mess. The solution would be for MCV to host it on their forward servers - I could always ask them about this, but I suspect it may not be a positive response…
Cheers
Chris
