In going through the LuaUPnP Log I’ve found several strange errors i’d like to see if I can clean up
1. JobHandler_LuaUPnP::GetPluginVersionOnline
01 07/12/15 10:13:56.855 JobHandler_LuaUPnP::GetPluginVersionOnline failed to convert 5836 <0x2c077680>
01 07/12/15 10:13:57.042 JobHandler_LuaUPnP::GetPluginVersionOnline failed to convert 8231 <0x2c077680>
01 07/12/15 10:13:57.419 JobHandler_LuaUPnP::GetPluginVersionOnline failed to convert 8301
and
2. Dropping due to collision
02 07/12/15 10:14:12.186 ZWaveJobHandler::DoReceivedFrame m_iFrameID 363 dropping due to collission with job#65 :getnodedetails 14 dev:756 (0x17be4e8) P:38 S:7 node 14 <0x2c277680>
02 07/12/15 10:14:12.296 ZWaveJobHandler::DoReceivedFrame m_iFrameID 364 dropping due to collission with job#65 :getnodedetails 14 dev:756 (0x17be4e8) P:38 S:7 node 14 <0x2c277680>
02 07/12/15 10:14:12.436 ZWaveJobHandler::DoReceivedFrame m_iFrameID 365 dropping due to collission with job#65 :getnodedetails 14 dev:756 (0x17be4e8) P:38 S:7 node 14 <0x2c277680>
[i][b] .... Repeats several dozen times ...[/b][/i]
Can anyone shed any light and guidance on these errors?
