Hello,
I have a Vera3 and a Vera Lite that work together on the same network. Both have UI5 1.5.622. I was thinking of upgrading the Vera Lite to UI7 to test compatibility of the plugins without risking the functionality of my Z-Wave network. Is it possible to have UI5 on the Vera3 and UI7 on the Vera Lite on the same network?
Thank you in advance,
/Mike
Come on guys… 38 views and no reply?
I have a Vera 3 running UI5 and a Vera Lite running UI7 on the same LAN. They both work as expected with no conflicts.
Thank you, i will try it out
/Mike
