I purchased two GE/Jasco ZW4005 Smart-Switches to wire in a 3-way setup. I originally had a aux switch setup, but since I use these to trigger scenes in addition to the lights, I needed the instant-on status update so I went with two full switches instead. The problem I’m having is that I don’t think it’s wired up correctly. I can’t use the 2nd switch unless the first switch is turned on first. Then once I turn off the 2nd switch I have to turn on the first one again before I can use the 2nd one. Like one switch is powering the 2nd switch rather than actually being a 3-way setup. GE doesn’t have directions for wiring this kind of setup, only the aux switches which are wired differently.
I found this diagram online for some Insteon switches which makes me believe I need to connect the LINE/LOAD wires inside the first box with a pigtail to the LINE input.
I have attached my current wiring diagram. If anyone can help that would be super awesome!
