My network setup Internet>Router>24 port Switch>Vera
In Vera:
Setup>Advanced>Net and WiFi
The firewall router is the gateway to the intenet, serves DHCP, and internal DNS server
If I select:
How can i connect to the internet?
Static
Firewall: No firewall
LAN: DHCP server: Off
IP:192.168.1.5
What happens is Vera starts handing out IP addresses to computers on the LAN.
The computers that received dynamic IP’s from VERA start using VERA as the gateway to the internet. So the all my DHCP computers instead of going out my firewall, they go through vera first, and then my firewall. So now all my internal network traffic slows down because VERA gets overloaded by everything going through it. Traffic starts colliding all over the LAN and my DNS server craps itself.
I had to turn DHCP on for how vera connects to the internet. That resolved my issues with traffic going through VERA.
I am also confused as to why VERA assigns itself two IP addresses? One for LAN and one for internet? I do not need the box to have two IP address’s. I will port forward traffic to the one IP address I assign static.
How should I setup VERA in my this network enironment?
