I moved into a new home recently and I used IKEA DIODER lights for under cabinet lighting. Due to the various placements of the lights, I ended up with 4 controllers.
Now that Fibaro RGBW are available in the US, I thought I would take a crack at it and ordered 4 of them after seeing a nifty youtube video of them running - obviously with no instructions on how to wire them. One thing I did like though is that they kept the DIODER controller intact and working along with vera, so I decided to do the same.
Here is what you need:
1 x IKEA DIODER
1 x Fibaro RGBW
1 Pack Arduino Compatible 6" M/F Premium Jumper Wires (I got mine from Fry’s but you can pick them up on NewEgg too: [url=http://bit.ly/1jmHNDQ]http://bit.ly/1jmHNDQ[/url])
[size=18pt]Step 1: [/size]
Install your DIODER strips and make sure they work correctly and you are comfortable with them
[size=18pt]Step 2:[/size]
Cut your jumper wires in half and strip the ends.
[size=18pt]Step 3:[/size]
Diagram: http://i.imgur.com/K6uyCV3.jpg
You are going to add both stripped wire ends into each of the following:
[table]
[tr][td]12/24vdc[/td][td]White[/td][/tr]
[tr][td]GND[/td][td]Black[/td][/tr]
[tr][td]R[/td][td]Red[/td][/tr]
[tr][td]G[/td][td]Gray[/td][/tr]
[tr][td]B[/td][td]Blue[/td][/tr]
[/table]
Here’s mine all wired up: http://i.imgur.com/d4PYjBI.jpg
Make sure they are good and tight in there as the Fibaro let some out when I was wiring them to the DIODER’s which made me have to take it apart and screw them in again.
[size=18pt]Step 4:[/size]
Attach the female ends of the jumper wires to the DIODER hub in the following order (when looking at it with the controller port at the bottom):
Black, Red, Blue, Gray, White
Same order for the males into the controller connector when its facing up and you are looking at the top.
This should clarify: http://i.imgur.com/9IsYhGO.jpg
Wired up: http://i.imgur.com/K1T6CUc.jpg
Make sure the DIODER controller powers on and changes color. If it works as it did before, then the Fibaro will also work.
[size=18pt]Step 5:[/size]
Put your Vera in learning mode. The Fibaro RGBW has an auto join so mine picked them up automatically. If it doesn’t, triple click the B button on the bottom of the Fibaro RGBW so it puts itself out there.
[size=18pt]
Step 6:[/size]
Make sense of the loads of _Dimmable Light that just showed up.
Each Fibaro RGBW will show up with 6 of these.
Edit each one, click the settings tab. If the ID is a number, this is your master On/Off/Dimmer and will report wattage usage etc. I name this RGBW - Controller.
The rest of them will show up with e1-e5 which are:
[table]
[tr][td]e1[/td][td]W[/td][/tr]
[tr][td]e2[/td][td]R[/td][/tr]
[tr][td]e3[/td][td]G[/td][/tr]
[tr][td]e4[/td][td]B[/td][/tr]
[tr][td]e5[/td][td]Does nothing[/td][/tr]
[/table]
There you have it.
My next step was to create scenes for a master on/off and for various colors. I will probably use PLEG to sync them better and also get some sort of wall mounted scene controller to turn them all on/off.
I hope this helps someone as I scoured the net looking for this tutorial and once I figured it out, I guess its my duty to put it out there.
