Okay. I made some changes so here they are..
First, the Logic Summary Report:
*************************************************** REACTOR LOGIC SUMMARY REPORT ***************************************************
Version: 3.2 config 301 cdata 19082 ui 19143 pluginDevice 558
System: Vera version 1.7.4453 on Sercomm G450; loadtime 1561026562; systemReady 1561026607; Lua 5.1
Local time: 2019-06-20T08:12:33-0700; DST=1
House mode: plugin 2; system 2; tracking on
Sun data: { "stamp": 2019169, "civdawn": 1560859750, "nautdawn": 1560857594, "sunset": 1560913382, "nautdusk": 1560917290, "latitude": Redacted, "astrodusk": 1560919652, "longitude": Redacted, "civdusk": 1560915134, "astrodawn": 1560855231, "sunrise": 1560861502 }
Geofence: running in long mode, last update 06:56:00, data version 2
User 1686711 ishome=0 inlist= since=06:56:00
|1472309878 "Redacted" type="home" status="out" since=06:18:00
User 1686611 ishome=0 inlist= since=06:56:00
| 1 "Redacted" type="home" status="out" since=05:42:00
User 2497352 ishome=0 inlist= since=06:56:00
|1559003821 "Redacted" type="home" status="out" since=06:56:00
Raw: { "updated": 1561043520, "users_settings": [ { "id": 1686611, "ishome": 0 }, { "id": 1686711, "ishome": 0 }, { "id": 2497352, "ishome": 0 } ], "mode": -1, "users": [ { "id": 1686711, "Level": 1, "Name": "Meritage1", "IsGuest": 0 }, { "id": 1686611, "Level": 1, "Name": "Meritage10", "IsGuest": 0 }, { "id": 2497352, "Level": 1, "Name": "TaylorS", "IsGuest": 0 } ], "usergeofences": [ { "geotags": [ { "radius": 250, "PK_User": 1686611, "id": 1, "status": "Exit", "accuracy": 0, "ishome": 1, "name": "Redacted", "address": "Redacted", "longitude": "Redacted", "latitude": "Redacted", "color": "006e45", "notify": 1 } ], "iduser": 1686611 }, { "geotags": [ { "radius": 100, "PK_User": 1686711, "id": 1472309878, "status": "Exit", "accuracy": 0, "ishome": 1, "name": " ", "address": "Redacted", "longitude": "Redacted", "latitude": "Redacted", "color": "#ff0000", "notify": 1 } ], "iduser": 1686711 }, { "geotags": [ { "radius": 250, "notify": 1, "id": 1559003821, "status": "Exit", "color": "ff0000", "ishome": 1, "name": " ", "address": "Redacted", "longitude": "Redacted", "latitude": "Redacted", "accuracy": 0, "PK_User": 2497352 } ], "iduser": 2497352 } ] }
Pool Spa Heat Off (#575)
Version 19082.17 06/20/19 08:09:34
Message/status: Not tripped
Condition group "Pool Spa Heat Off" (OR) false as of 14:12:41 <root>
|-F-group "Time Limits" (AND) false as of 14:12:41 <grpejs6xbl>
| &-F-trange after ,,,19,0,,,,, [1561043375 => 1561043412 at 08:10:12; F/F as of 00:00:00/00:00:00] <condejs74mp>
| &-F-service Pool Heat (529) urn:upnp-org:serviceId:HVAC_UserOperatingMode1/ModeStatus = Heater [off at 08:09:35; F/F as of 08:09:35/08:09:35] <condel0bjl7>
|-F-group "Time Limits" (AND) false as of 14:07:16 <grpejsekwh>
| &-F-trange after ,,,23,30,,,,, [1561043375 => 1561043412 at 08:10:12; F/F as of 00:00:00/00:00:00] <condejsexg0>
| &-F-service Spa Heat (530) urn:upnp-org:serviceId:HVAC_UserOperatingMode1/ModeStatus = Heater [off at 08:09:35; F/F as of 08:09:35/08:09:35] <condel0d017>
Activity root.true
Run scene 84 Pool Heat Off
Run scene 28 No Spa
Events
06/20/19 03:29:58 start:
06/20/19 03:51:19 action: action=Reset
06/20/19 03:51:19 sensorstate: state=false
06/20/19 07:54:55 action: action=Restart
06/20/19 07:54:56 start:
06/20/19 08:09:34 configchange:
06/20/19 08:09:35 condchange: newState=false, cond=condel0bjl7
06/20/19 08:09:35 evalchange: newState=false, cond=condel0bjl7
06/20/19 08:09:35 condchange: newState=false, cond=condel0d017
06/20/19 08:09:35 evalchange: newState=false, cond=condel0d017
06/20/19 08:10:11 action: action=Restart
06/20/19 08:10:11 start:
Scene #28 No Spa
Group 1
Device 91 (Spa) urn:upnp-org:serviceId:SwitchPower1/SetTarget ( newTargetValue="0" )
Device 93 (Spa Booster) urn:upnp-org:serviceId:SwitchPower1/SetTarget ( newTargetValue="0" )
Group 2 delay 30
Device 530 (Spa Heat) urn:upnp-org:serviceId:HVAC_UserOperatingMode1/SetModeTarget ( NewModeTarget="Off" )
Group 3 delay 600
Device 216 (Pump4 3450 RPM) urn:upnp-org:serviceId:SwitchPower1/SetTarget ( newTargetValue="0" )
Scene #84 Pool Heat Off
Group 1
Device 90 (Pump0 Main) urn:upnp-org:serviceId:SwitchPower1/SetTarget ( newTargetValue="1" )
Device 217 (Pump2 2200 RPM) urn:upnp-org:serviceId:SwitchPower1/SetTarget ( newTargetValue="0" )
Device 223 (Pump1 1400 RPM) urn:upnp-org:serviceId:SwitchPower1/SetTarget ( newTargetValue="0" )
Device 529 (Pool Heat) urn:upnp-org:serviceId:HVAC_UserOperatingMode1/SetModeTarget ( NewModeTarget="Off" )
Group 2 delay 600
Device 222 (Pump3 3000 RPM) urn:upnp-org:serviceId:SwitchPower1/SetTarget ( newTargetValue="0" )
And some screen grabs..
