hi
In pleg i have a trigger for when light is turned on. this seems to be true even when light is already on
i have it in a condition
lighton AND loadlevelstatus > 60
action set loadleveltarget to 60
i only want this to happen when light is turned on first time not when changing level of dimmer after that
my second condition loadleveltarget < 26
action setloadlevel target 0
turn light of when dimmer is so low light is off anyway
edit/
after light turns on and set to level 60. If i increase level to 80 it resets to go
Post status report as PDF … there are plenty of free PDF printers to print a web page as PDF.
You loose all the formatting … and make it difficult to read.
I have it in a condition
I only want this to happen when light is turned on first time not when changing level of dimmer after that.
Then you want:
lighton and loadlevelstatus > 60 and (loadlevelstatus; lightton)
New some guidance for below scene, does not seem to work with the 2 minutes timer.
Is actually for my walkway light, i wanted it to light for 2 minutes during vera plugin in night mode when motion is detected, and the light timer should restart when motion is detected within 2 minutes and off but if no motion being detect within 1 minute, lights to be immediately off.
Triggers
Name Description
tNight_Mode Night
Comments: Activate only in Night Mode
tWAlkWay_Motion Whenever WALKWAY SEN (Motion) is armed and detects motion
Comments: When Motion Detected in Walk way
tWAlkWay_No_Motion Whenever WALKWAY SEN (Motion) is armed and stops detecting motion
Comments: No Motion detected in Walkway
Schedules
Name On Type On Time On Days Random On Delay Off After Type Off Time Off Days Random Off Delay
sWalkWay_Light_Timer Self Retrigger None Interval 00:02:00 None
Comments: Walkway Light Timer 2 minutes
Conditions
Name Options Logic Expression
cWalkway_Light_On tWAlkWay_Motion and tNight_Mode
Comments: Walkway light on
cWalkway_Light_Off tWAlkWay_No_Motion and ( tNight_Mode; sWalkWay_Light_Timer)
Comments: Walkway_light_Off
Actions
Name When Defined Actions
cWalkway_Light_On Condition is True Immediate - 2
Comments: WalkWay Light on when motion detected in Night Mode
cWalkway_Light_Off Condition is True Immediate - 0; Delay 10 - 1
Comments: LigHt off after 2 minutes when no motion detected in night mode
Action: cWalkway_Light_On
Device Actions:
Immediate
Device Action Arguments
DIMMABLE LIGHT[285] SetLoadLevelTarget newLoadlevelTarget=30
NIGHT LIGHT SCENE[283] StartTimer timerName=sWalkWay_Light_Timer intervalTime=
Action: cWalkway_Light_Off
Device Actions:
Immediate
Delay 10
DIMMABLE LIGHT[285] SetTarget newTargetValue=0
Referenced Devices
Name Type
House Modes Plugin[115] HouseModes
WALKWAY SEN (Motion)[280] MotionSensorWithTamper1
NIGHT LIGHT SCENE[283] ProgramLogicEG
DIMMABLE LIGHT[285] DimmableLight
