Hi, newbie here ;D
I am trying to configure this scene to turn on the lights and TV when it detects movement and turn off the lights and TV when it doesn’t detect movement for a while.
Im using this luup code
local sensorDeviceNo = 23 – Motion Sensor device number
local lCacifos = 12 – Luzes Cacifos device number
local tTv = 11 – Tomada TV device number
local period = 300 – Seconds
local SS_SID = “urn:micasaverde-com:serviceId:SecuritySensor1” – Security Sensor Service ID
local SP_SID = “urn:upnp-org:serviceId:SwitchPower1” – Switch Power Service ID
function checkLastTrip()
local lastTrip = luup.variable_get (SS_SID, “LastTrip”, sensorDeviceNo) or os.time()
if (os.difftime (os.time(), tonumber (lastTrip)) >= period) then
luup.call_action (SP_SID, “SetTarget”, {[“newTargetValue”] = 0}, lCacifos) – Turn off Luzes Cacifos.
luup.call_action (SP_SID, “SetTarget”, {[“newTargetValue”] = 0}, tTv) – Turn off Tomada TV.
else
luup.call_delay (“checkLastTrip”, period) – Check when the sensor was last tripped every seconds.
return true
The problem is while the sensor its detecting movement the lights and the tv keep turning off and they don’t turn on after that.
What i am doing wrong?
Thanks in advance
