Turn on light if valid lock pin is entered
found similar questions but no solution.
[ol][li]When a valid lock PIN is entered a light inside should turn on.[/li]
[li]If it was an invalid lock PIN the light should turn back off after 10 minutes.[/li][/ol]
Trigger for a single valid PIN to run a light-on scene is easy, and I’ve got about 6 triggers set up - 1 for each PIN. Works perfectly.
But can i create a single trigger to run if any good PIN is entered? or if PIN 1, 2, 3, 4, 5 is entered?
What about trigger for light-on scene and light-off scene after 10 minutes if bad PIN is entered?
Lock is Yale
For a wild card pin … specify the pin # as:
You can create multiple scene’s to control your logic … or look into using PLEG.
