I have a motion sensor on my deck (Multisensor 6). I can very easily make it turn the lights on when motion is detected. But, the only behavior I can find for turning the light off is basically X time later, turn the light off. This is a problem because it will turn the light off after X time whether there is new or continued motion or not. What I want is for it to turn the lights off X time after the last time motion was detected. That way if it is re-triggered within the delay time, the timer basically restarts. The same way any other motion sensor light works.
How can I do this, either with a scene or with PLEG?
My logic also involves the state of the garage door and another occupancy sensor in the garage, but I think you can see the basic method.
Triggers on the light and the motion detector.
An associated condition for the motion detector to start a timer. The trigger needs to be Self ReTrigger, and the condition should be repeats = yes, so each motion restarts the timer.
A condition to turn on the light (night + motion).
A condition to turn off the light (no motion + motion timer expired).
An optional condition to handle a manual turn on or off of the light which if used, would start a timer and be references by the on and off conditions…
