Does anyone know how I can turn off the Horstmann Radiator Thermostat/Or not make it function?
The reason I want this is because the setpoint can’t be set below 5 degrees,
so now I have to delete the associations group ID 2 I’ve added, when I don’t want it
to turn on the heat.
I’m thinking there must be an easier way?
You can’t turn them off. You sure you want to, though? Most rooms rarely go below 5 degrees and when they do you might want a little heating to protect against frost damage.
What you could do is get a Fibaro on/off relay module, and wire the relay in series with the Horstmann boiler unit. Then you can use the Fibaro relay to switch off heating completely.
Yes I’m sure It’s for my cabin, and that room don’t need heat. In the winter when i’m not there for some weeks, the temperature can drop as low as -25 outside, then the room gets very cold.
The Horstman controls a fibaro that is connected to the heat, I was hoping that I didn’t have to use one more, even though it was a good idea.
