I first enter this URL in my web browser: https://sta1.mios.com/locator_json.php?username= myusername, and it replied me a list of information including my vera lite IP address, serial number… etc.
Your approach looks to be spot-on. I think you are being bitten by a typo that you haven’t seen. Perhaps post the actual real URL that you are using so that we can inspect it? Also be sure that device 5 really has a Switch Power service.
The DeviceNum I checked from Micasaverde user interface-device-the tool icon there. It shows Device #6. and the name of the device is Dimmerlight. I only changed these 2.
An easy way to do this is to go to go to http://<vera_ip>:3480/data_request?id=lu_invoke for your Vera IP. This lists all your devices. When you click on a device, it will give you things you can do for the device. Just copy the URL for what you want to do and plug in the appropriate value.
Hi OtisPreslsy, It is working very well! Thanks a lot!
Is it possible to access the scenes also? I tried all in http://<vera_ip>:3480/data_request?id=lu_invoke, for devices is working very well, but I didn’t find the one to control scene. Is there URL for scenes also?
[quote=“AvocadoKnight, post:5, topic:181187”]Hi OtisPreslsy, It is working very well! Thanks a lot!
Thank you!
AK[/quote]
No problem! You should be able to use this for running a scene: http://<vera_ip>:3480/data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=RunScene&SceneNum=
There’s your problem: don’t change this string from the example you were given. The original string (Dimming1) describes what your device can do, not what you called it. Your device’s name doesn’t feature in the URL at all. Only the numeric device number.
Using this URL I can successfully control the scenes already =) Thanks a lot! Can I ask how do you know these URL? Is it also from the reading material online? Since I noticed that they are slightly different from the Simple UI which I am reading http://wiki.micasaverde.com/index.php/UI_Simple. Is it okay for you to share a link so that I can refer to? Since currently I am doing my 3rd year project. I just tried to get more information, thinking that it may be helpful.
Hi, I actually have one doubts. When I connect the vera Lite at home, I was using my home Wi-Fi, it is totally okay. But when I try at school, using school network, I can’t connect to vera lite…It is very weird…
When I connect to school Wifi, it always shows "Unable to communicate with your unit. Please be sure the unit is powered and connected to Internet.
Try again
Setup your network or
Upgrade your firmware or
Activate remote assistance
Request tech support"
But I’ve checked the 1st three led on my vera lite are light up. So it is powered and successfully connect to Internet.
Any suggestion to solve this will be appreciated.
Thanks in advance!
[quote=“OtisPreslsy, post:6, topic:181187”]Using this URL I can successfully control the scenes already =) Thanks a lot! Can I ask how do you know these URL? Is it also from the reading material online? Since I noticed that they are slightly different from the Simple UI which I am reading http://wiki.micasaverde.com/index.php/UI_Simple. Is it okay for you to share a link so that I can refer to? Since currently I am doing my 3rd year project. I just tried to get more information, thinking that it may be helpful.
Hi all, I am using URL to control the dimmer, is there an URL to achieve once enter it, it will increase the light intensity of the dimmer a bit? I am using this URL to access my dimmer: http://[my vera ip address]:3480/data_request?id=lu_invoke&DeviceNum= [myDimmerDeviceNum]. Should I explore from this URL, to do some setup?
Thanks in advance!
