Running PLEG 7.47 on UI7. Trying to update it.
First, I tried the URL which returned an “OK”. But it didn’t take. So then I hit the update button on the app details page.
Again, no update.
Any idea how I can get this thing updated?
Again, no update.
Solved.
Couple reboots and it is all working now!
[quote=“johnes, post:2, topic:188872”]Solved.
Couple reboots and it is all working now![/quote]
I seem to be having the same issue. I have noticed that i cannot save conditions and it have checked PLC and its running on 7.48 yet PLEG is running on 7.47
Both of these are set to auto update.
I then tried the following
To Update Program Logic Event Generator
http://YourVeraIP:3480/data_request?id=update_plugin&Plugin=3066
To Update Program Logic Core
http://YourVeraIP:3480/data_request?id=update_plugin&Plugin=3086
In that order using my IP and i got the OK but PLEG still shows 7.47
Done a number of reboots and nothing has changed.
Any thoughts?
PLC version 7.48 is only for the LATEST UI7 release.
If you are not updating your firmware … you MUST also disable the AUTO Update features of plugins.
Hi Richard
I am running 1.7.1419, latest version i believe are you saying that i have the right configuration having Program Logic Core ON 7.48 and Program Logic Event Generator on 7.47?
Sorry if i am being a little dim
That’s the correct configuration.
The PLEG and PLTS plugins will indicate if there is ever a version mismatch when you try to inspect any data in the plugin device.
But it does not have a Version check on the Vera Version … If MCV continues to change API’s I may have to add this as well.
Thanks for the info Richard
