Trying to understand Leviton zone controller
I recently purchased the Leviton VRCZ4-M0Z zone controller. I have read through this forum to better understand how to configure and use. Here is my summary:
  • Problems of joining into network; I didn’t have these issues using button 1 & 3 approach
  • There seems to be a range of issues when controlling non-Leviton switches
  • Controlling of switches directly from a scene
    • I think I did have this issue. I setup a scene to turn on several lights. I click on wrench for Leviton zone controller and go to scenes tab and select scene for on action. When I press on button on controller, the scene gets ran (I can see it turn green in webui and in the log), but only 1 of 3 lights turn on. The 2 that don’t turn are dimmers, the 1 that does turn on is a GE on/off. When I manually run scene it works fine. A workaround I put in place is I created a virtual switch that maps to the on and off scenes. Then I create a scene to control that switch. Then I use the virtual switch scenes under the zone controller properties. This makes everything work correctly except the LEDs.
From what I’ve read I think what is going on when you set the scenes under zone controller the Vera is no longer used and the controller is controlling lights directly, which is where the strangeness comes from? If the Vera is controlling scenes and the scenes work manually, then I’m confused. And my workaround circumvents the zone controller from controlling lights directly. I still need to investigate LEDs. I know there are several post in the forum on that topic too. Did I get this right?
@nkskjames - I just hooked up an VRCS4-M0Z today to test it out. Still working on it but here’s what I’ve found so far. If I set it up to control scenes from the Scene tab and then unplug my Vera the Leviton will still run the scene. That tells me that the Vera is programming associations into the device so that it works without Vera.
So far I’m controlling a Linear dimming light switch, a Linear lamp module, and a GE/Jasco outdoor appliance module. They all seem to be working ok so far although I had some weird issues at first. After a couple of hours things seem to have settled down and for the moment it is reliable. I’ll keep testing and post any results here.
