Trying to trigger Home/Night/Away
Hello Community,
I’m hoping someone can help me out. I’m trying to create a scene that will put Vera into the appropriate Home/Night/Away mode based on a trigger from my DSC alarm panel (using Envisalink 4).
In the scene, I’ve tried all the detailed Alarm states as a trigger, but no matter what mode I use to set my alarm, it goes into Away mode. For night mode, on my Alarm panel I press “Stay, *1”. The *1 activates the motion sensors on the ground floor.
Has anybody had any success with this?
Thanks,
Jason
Hi Jason,
I use the HouseModes plugin to change the mode of the Vera…
This is what one of my scenes look like (no Luup code)
Step 1: Select a Trigger
1 Device Trigger
dsc partition 1 is armed Stay
Step 2: Device Actions
What do you want to have happen?
Immediately House Modes Plugin Night…
Here is another scene, using Luup to change the mode of the Vera:
1 Device Trigger
dsc partition 1 is Armed
This scene runs…
When I’m in the mode Home
When this scene runs…
Also, execute the following Luup code:
function lights_on() if (luup.is_night()) the…
luup.call_action(‘urn:micasaverde-com:serviceId:HomeAutomationGateway1’, ‘SetHouseMode’, { Mode=2 }, 0)
(this switches the Vera into AWAY mode)
Hope that helps.
Andre
