I got a Wintop iSensor 3-in-1 motion sensor. I thought it’d be similar to the HSM100 and the likes. It got included and configured without issues. I ended up with 3 sensors. Temperature (works fine and gets updated), light-level sensor (somewhat OK); however, it does not detect any motion at all. Checking properties, it doesn’t even have the usual settings for motion detectors (Sensitivity , On time , LED on/off , etc.) . I also noticed under the advanced tab that there are no variables for “trip” and “last trip” … Any ideas what’s up with this?
Using Vera Lite, v 1.5.346.
Motion Device capabilities: 83,156,0,4,32,0,R,B,RS,|48,49,96:2,112,113:1,114,128,132:1,133,134,
I finally got it working (the motion part) , after a few excludes then includes (while near Vera). 8)
Next thing to do is to tweak the “configuration settings” a bit (like sensitivity and re-trigger period, etc.) but there’s no documentation whatsoever (that I can find) that shows the device’s configuration settings :-\
Same here, I got it working after an exclude and leaving it by the vera for a long time. But I also need to figure out how to set it properly. It remains tripped for a very long period.
[quote=“capjay, post:5, topic:171646”]I finally got it working (the motion part) , after a few excludes then includes (while near Vera). 8)
Next thing to do is to tweak the “configuration settings” a bit (like sensitivity and re-trigger period, etc.) but there’s no documentation whatsoever (that I can find) that shows the device’s configuration settings :-[/quote]
I am having the same issue with the isensor staying tripped for a long time. Do you still have the documentation? Smarthome have moved to the Aeon Labs 4 in 1 sensor so the link posted is now different.
