I have 2 Veralites in a building and I’d like to bridge them. However, after reading up and trying to follow the instructions, I still can’t seem to get it done.
When I go to Devices - Add Devices - UPnP Devices - Next (on the Veralite I would like to be the “master” controller), I cannot see the other Veralite. I have tried this process on both units and get the exact same results. Both can see a Panasonic network camera that is on the network. I have checked the box to scan for UPnP devices and came back 15 minutes later, as well as reloaded and rebooted both Veralites. Both units are connected to a somewhat standard layer 2 switch (Cisco SG300 series, which is actually a layer 3 capable switch, but in layer 2 mode). Since they both can see the camera via UPnP, UPnP seems to be working (though I’m not 100% sure). Both units are setup with automatic network settings, but I have DHCP reservations configured so that they always get the same addresses.
I’m stumped. ???
Any help would be greatly appreciated.
Thanks!
DK
