Does anybody know of a company that makes compatible trip sensors? They seem they would be much more useful that all the door ones that are easily found.
http://aeotec.com/hidden-z-wave-door-sensor
This is at least hidden from view before the door is opened. Is that what you’re looking for?
What is a trip sensor?
break beam
I haven’t seen any wave enabled but there are plenty with output contacts with which you could wire a wave relay.
What is a trip sensor?[/quote]
Laser running across an area which could trigger a scene if you walk through it. I’m more looking for a way to identify where somebody is and in which direction they are moving. The thing I don’t like about the door sensors are that if they open, are you coming or going? The motion sensors I’ve had bad luck with as sunlight seems to trigger them.
A pic of an Everspring Door Sensor relay (removed from it’s case) here:
http://forum.micasaverde.com/index.php/topic,22594.msg153157.html#msg153157
Must provide laser and power.
