Is there a way to create a trigger that knows the difference between away and stay. I want to create scene’s and triggers that do different things if I put my alarm in a Stay mode or a Away mode.
Thank you,
Jeff
Thank you,
Jeff
for the AD2USB?
If you look at the triggers they exist for Alarm Detailed State in the trigger list for the device.
Is it safe to say the following?
select Device is Armed Away or Device is Armed Away for your trigger. photo attached
DSC doesn’t show armed away as a option as the screenshot attached shows. I will test device is armed and device is armed stay and see what happens. Thanks for all your responses.
that’s where I’d start
good luck
