Good morning all question, I am running a Vers 3 I am trying to set up a scene that will not start till 6 pm then when a door is opened it will open a light for 45 seconds then turn it off. I got the light to go on when the door opens and go off 45 sec later but i can not get it to start at the time i said. Would love some help
you want to turn the light on if it is after 6pm and then the door is opened, or do you want to turn on the light at 6pm if the door was already opened?
You should find a solution in Conditional Scene Execution.
