My motion sensor triggers have stopped responding after the latest update.Reinstalled PLEG and Core.
Log shows “WatchTriggerProperties : InvalidTrigger :tOM1”. A device property for the tripped variable works fine.
I tried reentering them several times.
Edit: Also Device Properties from a multistring variable are not getting updated.
VeraPlus Firmaware 1.7.1975
The switch added fine but the motion did not.
I really hope this is not me doing something stupid, but I have worked on it for hours trying everything!
I tried triggers from other devices and they work. It seems to only affect Motion sensors.
I have tried changing the EVENT TYPE and it still does not work.
Parameters for motion devices do work.
RTS, You are the best! Motion triggers are now working.
I was going to write this earlier and tell you it was still not working, but after a couple of reboots it started working correctly!
Maybe I should have stayed in bed … They are working for me now … they were not working a few mintutes ago. It was like and old version was running then.
Can you tell me if the fix regarding new motion sensors is already in place?
As i mentioned before i also experienced the issue that no information was coming to the PLEG
After some updates my existing motion sensors start working again, so i thought all issues are solved. But today i added two new motion sensors and here i’m having the same issues.
They work perfect in the standard Vera software, but not in PLEG. (again no last true or false data is received).
