How can I set the scene triggers to send alerts to more than one person and several times for the same rule
Thank you
J
Did you define multiple users? If not then log in to getvera.com->Control (top right)->Remote Access. Once you are logged in go to Users & Account Info->Other Users->Add Users. Once you have added your users, go to your scene and under step 3 “When this scene runs…” select “Notify these people:”. Then select all the users that you defined and that should receive an email.
I am not quite sure about the best way to send multiple emails. One solution might be to create multiple scenes with the same trigger that do they same thing, i.e. sending a notification. You could also create a “Notification Device” that sends multiple notifications but that involves quite a big of programming. Maybe VeraAlert plugin could do it. There is a 30 day free trial.
