I’m trying to replicate the function of two power saving modules in the Vera and I think its not possible with just a scene trigger but I thought I would ask
First the simpler module I have has two outlets on for the computer and one for all dependent devices, when the outlet with the computer senses the power level goes above a certain level it turns on the dependent outlet and vice-versa.
I have two Aeon power cords which sense Wattage being drawn - but the scene trigger does not allow for a trigger on level - It only allows for Device On , Device Off. Which I believe is only when you press the button or a command is sent to the device.
Without knowing too much about whats happening inside the Vera I’d think this sort of trigger could be implemented as temperature sensors can have a “when level reached” trigger.
The other type of module I was looking at implementing is one which when the power drain goes below a certain level it turns the device off after a time delay. When it senses a remote control being operated it turns the power back on. If the remote control does not actually turn on the plugged in device then after the time-delay it will turn off again.
This is used for turning of devices which use “standby” power. I’ve not started on this , but if the first scene trigger can’t work then I can’t get this one to work either.
So, my questions are: Is a trigger on a power level possible? If not, can someone suggest an alternate way of doing this. I had a look at the Wiki and I was thinking of using the Christmas tree light example to poll the devices power level and run the scene to turn off the cord based on that, With only one dependent device I probably don’t need a scene but I could probable use it later to turn down the A/C in the study etc etc
