Is it possible to trigger a fire event in Powermax using a Fibaro smoke detector? Or is communication only working one way, Powermax to Vera?
There is no (known) way to generate an alarm on the PowerMax via the serial interface.
Thanks, nlrb. Then I’m probably better off buying the fire detectors that come with the alarm.
Can I separate a fire alarm from an intrusion alarm in Vera?
Yes, did you look at the wiki?
For the panel, the following notifications are available. Alarm type, being either Intruder Panic Emergency Tamper Fire Flood Gas
Aha, thanks for the hint. Very nice wiki.
