I am trying to create a scene where the trigger is seeing motion on a motion sensor, and have the action be to change the color of our hue bulb in the living room. Not sure what I am doing wrong. I have attached all the screenshots below any suggestions would be greatly appreciated. Thank you!!
Your first screenshot shows turn the lamp immediately off not on.
I went back and tried to recreate it again and it defaults to Lamp off, I am not sure how to change it?
Since the Hue bulbs have two devices - the dimmer device and the color control device - you will probably need to include both devices in the scene… turn on the light with the dimmer device and then change the preset on the color control device…
The color control device does not have an switch device, and this may be what is “confusing” the scene.
