I can create scenes and trigger events based on certain rules, but I’d like to trigger an event when any button is pressed on my Schlage door lock. Basically, if someone walks up to the door and presses any button (regardless if they input a correct pin code or not), I want my lights to come on if it’s nighttime. I can get this all working using a little but of LUUP code, but only upon entry of a pin code. Is there any LUUP code that I can use to do this?
