I’m learning pleg, I have coding experience, so I pretty much get pleg. That said I have a trigger that pleg seems to always evaluate as true. I have a virtual switch set to “away” I have a trigger that should fire when my door lock is unlocked to switch off the "away"virtual switch but for some reason pleg shows this door unlocked as always true, never false. I tried using “now” but the granularity of now is limited to 60 seconds. It’s like the trigger is more being thought of as a state, rather than a trigger. From the triggers status page:
Triggers
Name Description State Last True Last False
AwaySet Home Control Switch 1 is turned on false 2014-12-08 08:16:47.034 2014-12-08 08:36:47.179
FamilyUnlockDoor PIN Code #3 is entered on Front Door Lock true 2014-12-08 08:35:41.818 0
If I create a simple scene in Vera using door unlock above as trigger this works, so what’s pleg doing differently?
Suggestions? I’ve googled the hell out of this, and I’m stumped.
Paul
