Trigger a scene based on DUSK/DAWN?
I know I can set a scene based on like 6AM/6PM, but if I want security lights on at disk off at dawn, isn’t there a way to do that without a light sensor?
Seems like since vera knows where I am, it should also know what time it gets light and dark in my zipcode? Similarly it should also know what my current weather is - rain, windspeed, temp, humidity, etc (which would ALSO be a nice scene trigger to have)…
Daylight savings and seasons make for a lot of annual tweaking otherwise…
Thanks gurus!
Whilst you can use lua ‘is night’ I prefer to use the ‘Day or Night’ app as it allows an offset from dusk and dawn.
Slartibartfast thanks I didn’t think of looking at the aps. I see temperature and rainfall in there also. Great suggestion! 8)
Also, directly in UI7 for scenes if you pick the daily schedule as the trigger, you can select sun rise or sun set with an offset instead of a specific time.
Shallowearth I’m not seeing that option (Vera lite UI7):
Select Interval (example: recording video every hour), or Daily, Weekly, Monthly to repeat schedule automatically, or One-Time scheduling.
You are running the latest version: 1.7.730
I installed the day/nite ap, but I don’t see anywhere to use it in scene creation? It doesn’t appear as a virtual device, or on the schedule tab?
[quote=“spydox, post:5, topic:189977”]Shallowearth I’m not seeing that option (Vera lite UI7):
You are running the latest version: 1.7.730[/quote]
No need for a plug-in. As stated Vera does this already with scenes. I just pulled it up (I use PLEG, not scenes). First, add a scene. Select Schedule for the trigger. Click the slider “button” area under Daily. Where it says “At time of Day” it is a drop down menu. There is where you select sunrise, sunset, before sunrise, before sunset, after sunrise, after sunset.
Installing the app should have crested a device called day or night that looks like a sun or a moon .
Also, in UI7 you select daily in the scene and then you get the option for sunrise, sunset, before, after. Just use this.
DOH sorry guys- its all there in the dropdown… as RHINESEL said
Thanks for the help and patience.
:smiley:
Here is screen shot of the sunrise/sunset options in UI7
[quote=“spydox, post:9, topic:189977”]DOH sorry guys- its all there in the dropdown… as RHINESEL said
:D[/quote]
NP, trust me, we’ve all been there. I often live there.
thanks shallowearth. I see it now. As my wife says I have to be hit with a brick sometimes to wake up ha! :stuck_out_tongue:
I still use the Day Or Night plugin … even though you can do this in PLEG (And Scenes).
The design principals for this follows:
[hr]
The reason … it is my Day or Night Mode switch. Sometimes I want day/night behavior at times other than normal. Then I can manually set day or night.
I can also test my day logic at night and my night logic during the day with this mode override.
I do not find the UI7 modes useful … Mostly because my DAY - NIGHT modes are orthogonal to my HOME - AWAY modes.
I also have Weather Modes (Freeze, Windows - Open Fan Mode, Windows - Closed HVAC mode)
Also my TRAVELLING mode is a specialization of AWAY … when I am AWAY for more than 8 hours.
The UI7 modes do not allow that kind of flexibility.
My Modes are set automatically … i.e. they change the Day/Night device or a Multi-Switch state.
My automation logic operates on the MultiStwitch values and Day/Night settings.
It was intentionally designed such that the logic that knows how/when to change modes does not deal directly with what happens when modes change.
Using a PLEG schedule with sunrise/sunset settings violates this design … unless it is being used to change the mode.
RichardTSchaefer
Thank you that’s a very good explanation. I think for my purposes the day/nite will be ok, but I do wonder about their criteria. I suppose its mostly just a matter of sunset/sunrise for my zipcode, which is close enough for security lights. But there are other factors like clouds, rain , etc that can make “dark-thity” earlier than sunset?
Best wishes!
