First post, all new to VeraPlus here, have it set up with a plug module, a Weiser door lock and Aeon Motion-sensor 6.
In the UI connected directly with my local ip I can view the alerts/logs but everything from today (even a few minutes ago or less) only shows up if I filter for YESTERDAY or THIS WEEK. Using the default TODAY or switching to TODAY shows no entries. If I try to filter by date range it won’t let me select today.
The alerts are dated with the correct date and time. I can’t find where VeraPlus shows the date anywhere else but it knows correctly today is Monday.
Is it just me or is it off by a day for everyone? It’s a bit frustrating to have to manually select yesterday to see today’s stuff. Seems like a silly problem.
- could it be the filter is not properly observing the time-zone? Most of my test activity has been in the evening and I am GMT-05:00 here. The time-zone is set properly on the Unit Settings page.
Firmware is 1.7.2414
