Hello
I just replaced my Everspring plug dimmers with TKB since the everspring dimmers are faulty most of the time , TKB dimmers are good and reliable but i have a problem with them , when i turn on the light it doesn’t gradually turn it on , it acts like an ON/OFF switch but when i turn it off it turn the lights down automatically , anyone faced this before ?
I too have just purchased some TKB dimmers and mine work in exactly the same way with my VeraLite.
Can I ask what happens if you toggle the on/off of the dimmer via Vera several times (2/3 times)?
If I do this on mine it seems to ‘crash’ them, and from then on I cannot turn them below 10% dimming via sliders or off via the button.
Yes. Same happens with me here. It doesn’t turn off I have to turn it off manually from the dimmer itself for it to function again
Not that happy with them for this reason, considering returning them
Same here. I’m in Egypt and bought them from UK. It’ll cost me like 50 pounds to return them
Ramii have you raised a support request with vera about it?
It’s not a problem with Vera , i tried them with fibaro HCL , same problem .
I sent to versternet and they confirmed that they have people reporting the same problem and they are looking into it .
Thanks for your help Rammi, I am also in contact with Vesternet although do not have access to a Fibaro HCL, so that is very very useful
