Here is a tip to save information on the Vera from javascript (client side).
The javascript part :
function _getCgiUrl() {
var protocol = document.location.protocol;
var host = document.location.hostname;
var httpPort = document.location.port;
var pathName = window.location.pathname;
var cgiUrl = protocol + "//" + host;
if ( pathName.indexOf( "/port_3480" ) !== -1 ) {
// Relay mode
pathName = pathName.replace( "/port_3480", "" )
if ( httpPort != "" ) {
cgiUrl = cgiUrl + ":" + httpPort;
cgiUrl = cgiUrl + pathName.replace( "/data_request", "" ) + "/cgi-bin/cmh";
return cgiUrl;
function upload( fileName, content, contentType ) {
var blob = new Blob( [content], { type: contentType } );
var fd = new FormData();
fd.append( "upnp_file_1", blob );
fd.append( "upnp_file_1_name", fileName );
$.ajax( {
method: "POST",
url: _getCgiUrl() + "/upload_upnp_file.sh",
data: fd,
contentType: false,
processData: false
.done( function( data ) {
console.log( data );
upload( "test.xml", "<xml>test</xml>", "text/xml" );
The LUA part to use the content uploaded :
local decompressScript = [[
decompress_lzo_file_in_tmp() {
SRC_FILE=/etc/cmh-ludl/$1.lzo
DEST_FILE=/tmp/$1
if [ ! -e $DEST_FILE -o $SRC_FILE -nt $DEST_FILE ]
then
TEMP_FILE=$(mktemp)
pluto-lzo d $SRC_FILE $TEMP_FILE
mv $TEMP_FILE $DEST_FILE
fi
function loadFile (fileName)
local lfs = require("lfs")
local path = ""
if lfs.attributes("/etc/cmh-ludl/" .. fileName .. ".lzo", "mode") then
path = "/tmp/"
os.execute(decompressScript .. "decompress_lzo_file_in_tmp " .. fileName)
local file = io.open(path .. fileName)
assert(file ~= nil)
for line in file:lines() do
-- do something with line
file:close()
