I’m new to vera and it’s environment, so greetings to everyone here.
I recently installed datamine and everything seems to work, data is logged and channels are updating.
The problem is that the data logged is one hour behind the actual time shown on vera.
If vera’s time is 14:00, the events get logged at 13:00, so when I see the graphs, I need to add an hour to every measure, which is kind of odd.
Also DM reports with the yellow sign that it has no recent data.
Does anyone know how to fix this so the data is looged correctly?
If I use the graph’s name to display in a browser it shows the time off by an hour. If I go to dm/index.html in the browser, then select the same graph, the time is correct.
