This version of C:\Intel\nssm.exe is not compatible with the version of Windows
When I try to run the ConciergeServer.jar on my Windows 10 Home, I get the following error:
“This version of C:\Intel\nssm.exe is not compatible with the version of Windows you’re running. Check your computer’s system information and then contact the software publisher.”
Did you install ConciergeServer.jar in the c:/Intel directory ?
If not you have an old version on your computer and your path is pointing to it.
Yes, I did. It created the nssm.exe file (along with a few others) when I launched the jar file and produced the error message. I can’t launch the config interface thru the browser…i get this:
Hmm, we can’t reach this page.
Try this
Make sure you?ve got the right web address: https://localhost:8989
Refresh the page
Search for what you want
I tried a different (newly created) folder than C:\Intel, but it didn’t work there either.
If it helps, I am trying to launch this on the same PC that HA-Bridge is running.
I downloaded nssm from https://nssm.cc/download and i was then able to config the server.
