I have tryed to log the wattaged from a Fibaro Wall Plug to Thingspeak.
But it only sends the 0 Watt.
I have a Well Pump pluged in to the Wall Plug, so I know there is a watt usage, but maybe only for 5 sec. every 2 min.
Can you see what is wrong?
Regards Jens[/quote]
Should work. What are the Watts values you have on Vera ?
Do they include a . Or a ,
What this the decimal point setting of your lua box ?
What is your config ? Ui5 ui7 openluup? Versions ?
If that doesn?t help finding a root cause then please
Enable debug mode on altui force ? luup reload , wait til at least one value is sent and send me the logs
The Watt value is with a . in the Vera UI.
I don’t know the decimal point setting of my lua box, I believe the standard setting? Where do I see that?
My config is UI7 version 1.7.3532 on a Vera Plus. With AltUI v2.24.2383, ? 2018 amg0,50103835, 1.7.3532
[quote=“amg0, post:2, topic:199135”]Should work. What are the Watts values you have on Vera ?
Enable debug mode on altui force ? luup reload , wait til at least one value is sent and send me the logs[/quote]
Enable debug mode on altui force ? luup reload , wait til at least one value is sent and send me the logs[/quote][/quote]
Thx all seems correct. And I do use decimal point values successfully on mine so let?s go deeper. Can you do follow the debug mode steps mentioned above so we see what?s up ?
[quote=“kyle.dawson, post:8, topic:199135”]Not sure if this is a bug but starting to setting up ThinkSpeak and works great. But the default value seems wrong for Graphic Url.
Once I type in http:, the graphic shows up. But I have to do this for every single one I do. Kinda of a pain.[/quote]
the protocol is not specified such that both http and https work either well. you do not have to have a protocol specified, it would take the one of the current page. this way in remote access situation ( https with MMS gateway ) it still work
is there a specific place / problem that this generate ?
I get message that channel does not exist. As I went back in the AM, looks like you have to exit page first (Save). When you go back in it will works. I am good, just needed to finalize the info I guess.
