I have z-wave thermostats on each of the radiators in my house (EUROtronic StellaZ’s), I control with my VeraLite (UI5). The device controllers use the HVAC_ZoneThermostat:1 device category. However, according to the manufacturers of the device, the position of the radiator valve pin is given by the ‘switch multilevel command class’, which isn’t available within the controller’s variables. I think it is the same variable that dimmer switches use to control their brightness.
Is there any way of easily adding in this functionality?
Many thanks for any suggestions!
