Is there a way to show the thermostat temp reading?
Not sure if I have the latest controls for the Trane thermostat but mine shows the current set point but not the current temp.
It’s possible, but you have to add a separate control for it. Add a “Sensor Measurement” control, select your Trane thermostat, and it should display the current room temp.
© 2022 Ezlo Innovation, All Rights Reserved. Terms of Use | Privacy Policy | Forum Rules
