I’d love to see what others have done. My thermostat dashboard is pretty boring.
Also, I seem to remember some discussion about energy mode? I don’t see the ability to display or control energy mode (Trane ESM) in HomeWave.
Add a “Thermostat settings” control, like the square ones you have there to set the thermostat mode. Open its properties and at the top you’ll see “Controlling: Mode”. Click the blue arrow (or i sign) and you’ll be able to switch to controlling Energy Mode or Fan (if your thermostat supports it).
Ahh, great, thanks! I thought I’d seen it somewhere…
EDIT: No dice! It’s not there. I just get “fan” and “mode,” nothing related to Energy Mode. I have a Trane thermostat that definitely supports ESM.
I’d still love to see what layouts other users have put together.
Can you pull the user_data from your Vera using this URL (substitute the IP address with your own), and mail me the results please?
http://192.168.2.14:3480/data_request?id=user_data&output_format=json
I’ll have a look
[quote=“intveltr, post:4, topic:177436”]Can you pull the user_data from your Vera using this URL (substitute the IP address with your own), and mail me the results please? http://192.168.2.14:3480/data_request?id=user_data&output_format=json
I’ll have a look[/quote]
Sending via email!
Got it, thanks. I notice that the Trane device does not expose the eco mode in the standard uPnP HVAC_UserOperatingMode1 service like other thermostats do. There is a reported value for ModeStateForEnergy in a MCV specific service, but I’m not sure if that’s the right one. Does anyone know how the eco mode on the Trane thermostats are set through uPnP services?
